88 tpi Cracked flywheel =knocking motor
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
does any one know what causes your fly wheel to get cracked?? is it high rpm ? or is the stock flywheel not heavy duty enough for high rpm use??? I have a 383 stroker motor that was internally balanced. do i replace it with a 350 cub. fly wheel or a 400 cub. flywheel?
Car: 1987 TA
Engine: 350 stock/twecked
Hello,
I would recomend an SFI approved flywheel. On a modifed moter I would not use a stock fly wheel. have the flywheel balanced to you engine, and use good boolts like ARP. Also don't forget the lock tite. one more thing that I can think of is to check out the converter. Dose it fit in the crankshaft properly or not? Just a few ideas to check on. I almost forgot what is kyour stall speed. hard launches tear things up.
later and
GB
rick king
evilstuie
Jan 9, 2020 08:29 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Sanjay
Aug 12, 2015 03:41 PM
