tbi to tpi vaccum lines
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I will be converting my 92 rs over to tpi this summer but the whole vaccunm line and I guess cooling lines to some extent are what I don't know about. which lines will be to short and where do they go. to make this swap more complicated I am using a setup on an 85 iroc but am going to run it in speed density rather than MAF. I know the plenums on the later speed density systems had three vaccum lines coming off the left side and the maf only has two. what do I do about that. I did a search but because I am essentially doing three conversions at once (TBI to TPI MAF to TPI SD) I am lost. please help. pics would help even more so.
what are the 3 vaccum lines on the sd system? correct me if I am wrong. egr, fuel pressure reg., and map sensor right?
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
An easy way that helped me is i went to the dealership , showd them with vacuum line i needed , they were all be bent, cut to lenght , it was real easy to figure out which line went where. Not the best way to do things , but it worked for me......also check out ....www.chevythunder.com he has vacuum diagrams that helped me a little too.
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
