ideas on going from hard line to rubber?
Old Apr 24, 2004 | 08:35 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
i want to go from the hard steel line coming out of my crossmember to steel braded line to go up to the fuel rail fittings. any idea?
theres only about an inch or two sticking out of the crossmember so flarings out of the question.
i heard about compression fittings but don't know anything about them so i don't know which one to get.
the line sizes are 5/16 and 3/8. what are the stock camaro ones?
Old Apr 24, 2004 | 09:48 PM
maiors2's Avatar
Car: '68 Camaro
Engine: 327 TPI
Transmission: Powerglide
What you are looking for is a "hard tube adapter"(compresion fitting).Russell makes them.They have -06 and -08 AN fittings for 3/8" and 1/2" tube.I have used them before and the are easy to install.Just have a nice cut end.You stide on the bottom end then the compresion ring then the top.Tighten it up and you have a AN fitting on your stock tube.
I believe the stock line is 3/8
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
johanlindgren
Aug 16, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Kaweh
Aug 9, 2015 02:54 PM
