no IAC
Old Apr 25, 2004 | 09:10 PM
BryceW25's Avatar
Car: 87 Z28
Engine: Mini Ram II, 113 heads tpi
Transmission: 700-R4
no IAC
i put a new intake on my car and it nots idleing very well. on my stock intake there is a hole where the intake meat the throttle body where the IAC it at, but on my new intake the MINI II there is no hole, could this be a cause of the bad idle,, if anyone could help that would be great..thanks
Old Apr 26, 2004 | 02:33 PM
383 rocket bird's Avatar
Not having the IAC hooked up should definately cause a bad idle but I also have no experience with that particular intake. -John
Old Apr 26, 2004 | 06:54 PM
BryceW25's Avatar
Car: 87 Z28
would that efect the proformance of the car
Old Apr 26, 2004 | 10:34 PM
As far as performance goes my first instinct would be to say no, but I would bet that driveability will be comparable to a turd with a saddle. -John
Old Apr 27, 2004 | 07:57 PM
BryceW25's Avatar
Car: 87 Z28
ha....well do u think it is a good idea to make a hole on the new intake for the IAC
Old Apr 27, 2004 | 09:31 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The IAC air flows up through the throttle body. The hole on the TPI intake is for EGR air. Normally not neede when converting older vehicles to TPI operation.
Old Apr 28, 2004 | 08:41 AM
BryceW25's Avatar
Car: 87 Z28
ok, then if it not the IAC, what else can it be, timing, maybe TPS, or injectors anyother sensors, i just replace the O2 sensor on it because it has been runnin crappy when it warms up, and that didnt help it, i read some other threads and they said it could be the CTS???? On the stock intake there where to sensors on the front of the intake, one was it the CTS and the other i have no idea what it is, that maybe my problem. ha and one more question...By havein a EGR would that effect anything??
thanks for your help
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
