fuel injectors
Old Apr 29, 2004 | 01:05 PM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
fuel injectors
ok I'm trying to trace down a stumble in my car I check the codes it had a code 36 so i replaced the relay to maf. So no more check engine light. After i changed that it idled better and drove better, but at wot it stumbles really bad. so i wanted to know what you guys thought it could be. p.s. 87 gta 350 tpi. Also I tried to check the ohms on the injectors but i'm not sure what the ohm meter needs to be set on,but i put it on 20k. Thanks in advance Kevin
Old Apr 30, 2004 | 01:14 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Put your ohmmeter on it's lowest setting above 20 ohms. Not 20K ohms.
You may also have problem with a plugged fuel filter.
Old Apr 30, 2004 | 02:14 PM
Morley's Avatar
Also check your coolant temp sensor
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
