12's?
Old May 5, 2004 | 11:06 PM
MRIROC's Avatar
Car: 87 IROC
Engine: 355TPI SUPERRAM
12's?
think this is a 12 second combo? 355, accel base,w/superram upper, edelbrock performer rpm heads, crane 228/228 - .512/.512 cam, shorty headers,w/3'' single out flowmaster exhaust, 3.73 gears,w/auburn posi, msd ignition, stock suspension,305 chip,and so far i can only afford some street tires.im gonna try to get ahold of a 350 chip until i get 1 burned.im hopeing for 12.7 but i think thats a little to hopefull.ill be adding an nx kit later.
Old May 5, 2004 | 11:09 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I would think you'd need a custom prom to get the most out of that combination.
Old May 5, 2004 | 11:22 PM
MRIROC's Avatar
Car: 87 IROC
i know about the tuning but i dont have the cash to get it tuned right now.that will probably be the next thing on my list.thanks for the reply.
Old May 5, 2004 | 11:38 PM
REDZ28's Avatar
I think you should be able to get into the 12s with that. I went 13.11 with alot less then you have. Traction is the key!! Yes you will need a 350 chip and Injectors!
Old May 6, 2004 | 10:55 AM
OMINOUS_87's Avatar
That combo should run in the 12s all day long with no effort as long as you get it dialed in properly. It a nice selection of parts you picked there.
However you must have a proper chip in there otherwise the whole thing could end up to be a big bust for you.
Also be sure to run a decent freeflow exhaust with that single pattern cam.
Old May 22, 2004 | 01:27 PM
MRIROC's Avatar
Car: 87 IROC
SO IT SHOULD BE 12'S NO PROBLEM?
Old May 22, 2004 | 04:27 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
w/o tuning, it still should run 12s, but it will depend on weather etc. W/ tuning I would say no problem into the 12s!!
