Intake won't come off
Old May 9, 2004 | 02:39 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
I took off all the stuff on top of it and the distributor. All I found were 12 bolts. Took them off and the thing is like glued on.. Any advice on how to pry this thing off? Or did I maybe miss a bold somewhere?
This project is never going to end......
Old May 9, 2004 | 02:43 PM
vwdave's Avatar
It is going to be stuck on there. I had to pry mine off.
Old May 9, 2004 | 03:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Mine was stuck also, I took a heavy rubber mallet and whacked it on each side twice and it was very obedient after that.:lala:
Old May 9, 2004 | 03:51 PM
scanman717's Avatar
Engine: LB9
Finally!!
Thanks, I just wanted to make sure nothing was hiding on me... I actually had to pry a little with my breaker bar....
Hey, so thats off and the valley is just caked in crap... What is the best way to clean that out, without it all going into the oil?? Or maybe it shoudl go in there, I am going to change it before the first fire...
Now if I can just get the heads to come loose : )
Old May 9, 2004 | 06:28 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I have used various items to pull stuck intakes off, but the best was last time we put 2 fairly think sticks inside the throttle body openings and pried up w/ gentle pressure, making sure not to break the wood, until it came off.
1992rs/ss
Jan 31, 2025 05:10 PM
92projectcamaro
Jan 18, 2016 08:00 AM
hydrolic144
Oct 4, 2015 08:23 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
