Two code 42's in a week!
Old May 12, 2004 | 04:48 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
Last week i was cruisin around at about 40 mph, and felt a sudden loss of power and the check engine light came on.
The car felt like the torque converter never locked, the engine reved freely but the car didn't accelerate fast. Weird stuff.
Got home, checked the code its code 42. checked the resistance across circuit 423 to see if its less than 500 ohms like it says to do in tpi swappers guide. ohms were 2000ish. said loose connection or faulty ignition module.
couldn't find any bad connections, replaced the ignition module and bam it runs perfect for 4 days.
THen I'm cruisin along again and the same thing happened with the same code! What's goin on?
Old May 13, 2004 | 12:45 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
You replaced the ign. module in the distributor , but did you replace the Eletronic Spark Contorl Module , that is on the drivers side over by the burn off relay.
Old May 13, 2004 | 05:58 AM
Car: 1988 GTA
Engine: 355
no i didn't replace the esc. you think that could be the problem?
BumpaD82
Feb 26, 2016 02:57 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
