400 Cam Selection
Old May 16, 2004 | 12:37 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
400 Cam Selection
I'm looking at using the Comp
280AR(magnum) 280in/280exh adv 236in/236exh@.050 .550/.550lift 110LSA or the
XR274R(xtreme energy) 274in/280exh adv 236in/242exh@.050 .564/.570lift 110LSA.
Heads are AFR195's
Intake will be a HSR with the 730 ecm fueling it.
What idle characteristics will these cams have. Also posted in the engine swap section.
Old May 16, 2004 | 05:38 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
This is for a 305?
Old May 16, 2004 | 05:41 PM
eric305TPI's Avatar
NO
As the topic states its going in the 400 that I'm putting together.
10-10.5 compression, afr195 68cc heads, KB flat tops.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
