LT1 Manifold flow numbers
Old May 17, 2004 | 05:50 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Does anyone know exactly what type of numbers this things flows, Ive tried doing searches but ive come up empty handed.
Old May 17, 2004 | 07:50 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Plenty, the ports are slightly taller than a 1204 gasket, my l98 heads had the same size also. The kicker is here they are that size all the way through, unlike a TPI setup. If you want them to match a 1205 gasket, fire up the die grinder and start port matching. From what I measured a 1206 should be able to be used, but I didn't have the actual gasket and you would have to do a lot of grinding.
So my answer is... they'll flow what you port them out to flow, which should be enough to easily handle almost any big cube SBC. Even pro lightning 242's use a 1206 gasket
Old May 18, 2004 | 10:27 AM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
How would it flow in comparison to say the HSR?
Old May 18, 2004 | 06:05 PM
OMINOUS_87's Avatar
Results allways speak louder than flow numbers, there are a heck of alot of fast LT1 cars out there.
87iroctheo
Dec 4, 2016 11:47 AM
anesthes
42
Oct 24, 2015 07:30 PM
zayne0
Aug 24, 2015 07:22 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
