Stock 89 TPI base port
Car: 1988 GTA
Engine: 5.7L/L98
Although your description isn't clear, wouldn't the runner between the 3rd and 5th runner be the 4th runner
The only other openings on the runners are for EGR passage or the cold start port. The small tubes runnning next to the large runners are EGR.
My bad were talking about the base. Maybe PCV as Trickster suggested, or it could still be the EGR opening.
Car: 89 Formula
Engine: 355
Since you are on a roll, what is the port on the TB that is located below the fresh air port for? It was capped off when I bought the car.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is for coolant and used to have a hose going to the heater control valve. The circled "X: at the front of the throttle body is where the coolant enters the base of the throttle body from the hose at the front of the manifold. Rolling, rolling, rolling
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The carbon canister connects to the vacuum port on the side of the throttle body right underneath the fresh air port. Then you have the coolant passage underneath that... Heck while we're on the throttle body port kick, the port on the very bottom of the throttle body is ported vacuum for the egr valve.
Car: 89 Formula
Engine: 355
That is the one! Thanks for the info, will have to check my hose routings, that was capped when I bought the car.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by Insomniac92z28
Fresh Air?
Mine has been renamed the PCV port on the throttle body since it is used as such.
Fresh Air?
Car: 1988 GTA
Engine: 5.7L/L98
Fresh Air?
Fresh Air?
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
So the large "Fresh Air" port on the Pass side of the TB is supposed to be capped then? My PCV is on the drivers side and there is a chrome breather on the pass side.
Also, where does the "Fresh Air" port get its air? I would assume it just diverts some of the incoming airflow to the breather? Or is it from another source?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You got it!!!!!!!!!!!!!!!
Car: 1988 GTA
Engine: 5.7L/L98
If you mean the TB "fresh air" port it recieves incoming air from the TB cavity itself.
Car: 1988 GTA
Engine: 5.7L/L98
Dang beat to the punch by Trickster again, thats twice now in different post I have been typing a response and by the time I am done I see your post right in front of me. Your just to damn good Trickster:hail:
Engine: LS3
Transmission: 6L80E
OK...but on a MAF car, the MAF is reading X amount of air entering the engine, and so my question here (since the original question is for an 89 TPI setup) is that is this a problem?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What are you looking to setup there 88TPI406GTA, a TPI or TBI. The 89 TPI engines had the MAF as well as the 2.8L V6. The 5.0L (LO3) had the MAP system. The same thing applies to 90 and higher year model cars that have the TPI and MAP. Fresh air is routed from the Throttle body intake out the fresh air port to the breather valve on the passenger side valve cover.
Engine: LS3
Transmission: 6L80E
Actually, my question was theoretical. On my 91 (the same one I was having issues with the PCV Valve on) this port was open and I plugged it...it didn't really impact the engine running.
My theoretical question on a MAF setup was more to understand that there should be no air lost/gained after the MAF due to its accounting (roughly) for the amount of air that passes through it.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It won't neccessarily impact the MAF because it has already gone beyond that point. Where it would impact the MAF would be if you had an opening in the air duct prior to the MAF other than the air filter or running without air filters.
Engine: LS3
Transmission: 6L80E
Trickster...I hate to say this, but what you said makes no sense.
What I am talking about is a loss of air from or possibility into the system AFTER the MAF. Meaning that the MAF sees x amount of air and the "fresh air" port "leaks" out say 10% of that air. The ECM calculation will be off by that 10%.
This is analagous to running a Y inlet with the MAF on one side and the other end open...the MAF would only see 1/2 of the air coming into the engine.
My question rather was since the TB is AFTER the MAF, shouldn't it affect the ECM load calculation because roughly 10% less air is actually being fed into the engine, thereby making it richer?
The MAF system on our cars is a coarse system though and a little leak like this probably won't matter...otherwise it would have been a bigger issue already.
See where I am going with this?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'm not really sure why you are asking about the MAF when your car is designed and set-up with MAP. By plugging that port, what you are doing is increasing the pressure in the manifold by stopping the air from going to the breather valve from the throttle body. On the cars with MAF, that air is diverted at the throttle body after it has already been measured by the MAF sensor. The MAf sensor only measures air going through it, not what has already gone through it.
Engine: LS3
Transmission: 6L80E
I am curious because the GTA IS a MAF car...and I had never heard of this port before...
I guess that the stock MAF tables must take this into account then...
Car: 1988 GTA
Engine: 5.7L/L98
Hey 88TPI406GTA, The amount of air that can pass through that port is so minimal it would not affect the MAF readings enough to make a difference. There is no direct open port for air to be forced through on the TB port opening, Its more a series of passages to be able to draw air from designed into the cavity of the TB. So to answer your question simply theres just not enough air lost through that port passage to affect the readings from your MAF. It should be capped just to keep the inside clean.
Engine: LS3
Transmission: 6L80E
I think that part of my past experience is from newer MAF engines...like a 95 Eagle Talon I owned. It was the turbo 2.0, 5 speed, AWD. Basically I remember that there was an issue with the Blowoff Valve. The stock setup recycles back into the intake behind the MAF and some guys were venting to atmosphere. That was a bad idea and caused some real drivability issues. This was under boost and a different ECM, but I thought that the principle was the same.
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
