fuel pump blown and dont wana drop the tank help
Old May 19, 2004 | 06:03 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i remember there being and artical on how to cut a hole over the fuel pump and getting it out that way but i cant seem to find it?
does anyone have the link to this?
and also what company make a direct replasment high volume pump for my 89
thanks
Old May 19, 2004 | 06:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Jerflash,
Don't get me wrong on this, but have you checked the fuse in the engine compartment near the battery yet, And that looks too nice a bird to cutting holes in it if you don't have to.
Old May 19, 2004 | 06:35 PM
jerflash's Avatar
ya trickster the fuse is fine i have had the problem before
and i tried your lil take a hot lead to the g termanail on the a aldl and the pump does not go on
all i here is something clicking on and off which i guess is the fuel pump switch or am i wrong
so i think it is the fuel pump
so what do you think man
thanks or your help
oh and i took a volt meter to the back and put it on the hot lead of the fuel pump conector under the car and it has power
where is the fuel pump relay anyway even though its not bad i would like to change it also
Old May 19, 2004 | 06:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The clicking you are hearing is the fuel pump relay located under the hood on the driver side firewall. If you put power to pin "G" on the ALDL and ground without the fuel pump running it is definitely shot. Bummer man, I was hoping you wouldn't have to go through all that hassle.
Old May 19, 2004 | 06:54 PM
jerflash's Avatar
the battery needs to be grouned out right?
if not what needs to be grouned?
Old May 19, 2004 | 06:55 PM
jerflash's Avatar
i just put a power source to the g and heard the clickin
Old May 19, 2004 | 07:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes the battery needs a ground, you can ground it to the car frame or pin "A" of the ALDL.
Old May 19, 2004 | 07:32 PM
jerflash's Avatar
ya i need a new pump this sucks
i will ahve to pick one up tommarow
my 2002 is broken also thats what really sucks
Old May 25, 2004 | 03:04 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I did that when the pump went out on my '85 Z. I REALLY didn't wanna drop the tank because there is alot of work involved and I didn't have a proper facility to work in. I want to go on record as saying that dropping the tank is the proper procedure when replacing the fuel pump. So anyway, I cut a hole through the sheet metal above the tank to access the pump. I used a dremel and cutoff wheel (or several). After the install, I epoxyd the piece I had cut out back into place and replaced the carpet over it. There was actually a little more involved to it, but not much. I would advise using extreme caution if you decide to go this route as there is a danger of f*cking up your car and yourself. For example; I was told to use a brass punch to rotate the retaining collar on the tank so as not to create a spark, but of course I just hit it with a hammer. Not smart. Always work safe around gasoline! We don't wanna come visit you in the burn ward! :nono:
Oh, and good luck, which ever route you take.
Old May 25, 2004 | 07:12 AM
Chrome's Avatar
Car: 92' RS Camaro
I've dropped the tank before in a gravel driveway w/ ramps on teh front and jackstands under the rear. Its a PITA, but very doable. Granted now I would just take it to the garage (friends) and put it on the lift. But we're all young and stupid at one point or another.
I'd say took a good day doing it that way. (And that was w/ no air tools)
Old May 25, 2004 | 09:04 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
fuel pump
Ive been down this road a few times.
The easiest way to do this is cutting the material over the center of the gas tank. I got a drill bit and slowly cut two small holes on each corner of the center piece over the tank I believe a 1/4 inch drill bit.
Then get a pair of tin snips and just cut your self two straight lines and then one across joining the two together(wear leather gloves) then pull the sheet metal back towards you as far as you can.
Then get a small tubing cutter and start cutting the lines bend them up a little so you can fit the cutter underneath the lines to rotate the cutters.
You can lightly tap the locking ring back out going counter clock wise with a small screw driver.
Replace the pump and strainer and o ring seal.
I used 3/8 fuel line to patch all of the cuts on the metal lines and double clamped each side.
Push the sheet metal back down a hammer will help, after I got mine forced back into place there was only a crack of space where I had cut it with the snips I just bondo'd it up so that possibly no exhaust fumes come back into the vehicle through the cracks or carpet.
Old May 26, 2004 | 06:53 AM
Chrome's Avatar
Car: 92' RS Camaro
I agree it can be done that way. But why hack up the body even though it is a small part? For the time spent cutting the hole you could have the rear axle dropped. Then why your doing that why not put in some new Bushings/LCA's/Springs/Shocks?!?! Hit two birds w/ one stone if ya know what I mean.
Old May 26, 2004 | 09:43 AM
robsgta's Avatar
tank drop
Dropping the tank possibly 3 or 4 hour job and a helper or two trying to catch the tank & line the tank back up because it for some reason doesnt seem to drop right out at least from my experiences or line right bac up especially with fuel sloshing around in there possibly risking injury if you dont have a lift.
Doing it from the top is maybe an hour job with no help no special tools and your guaranteed not to spill fuel
Old May 26, 2004 | 06:15 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Took under 2 minutes to cut the hole (square actually) with the air chisel and a cutting bit.
Then, I gently cut the lines with a sawsall on low speed.
Then I removed the sender, replaced the pump, and put it back in.
Used seam sealer to put the lid back on over the tank..
-- Joe
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
