bad injector - replace all???
Old May 20, 2004 | 04:18 AM
gta88 flamered's Avatar
Car: GTA 89
Transmission: TH700
One of my injectors is showing an impedance of only 6 Ohms.
The other ones are between 17,8 and 18.1 Ohms. But two of these have been replaced in the past, they are looking different to the others....
Now I'm thinking about replacing all injectors at the same time...the Accel 150821 as a direct replacement will cost me 225$ + shipping + tax...the cheapest supplier here in Germany wants to have over 100$ for ONE!
I'm also afraid that another injector will go bad in a short period of time and I will have to make the whole work again...
What do you think is the best? Replacing all together???
Thanks for advice!
Jens
Engine is 350 TPI Code "8", Model year 89
Old May 21, 2004 | 04:41 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
gta88 flamered,
I have taken my TPI intake, runners, and plenum apart many times and it is never easy (or fun). If I was in your situation, I would replace all the injectors just to be on the safe-side.
Also, it seems like a bit of a waste to pull all that stuff off your motor for a single injector - then have to do it all again if another one goes out.
I put Accel 24# injectors in my car 3 years ago and have not had any injector-related problems since.
Hope this helps!
Best of luck.
Old May 21, 2004 | 07:27 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I don't know how many miles are on the those injectors but if there is a lot of milage I would replace them all. If they are relatively new anything can go bad. In that case I would only replace the bad one.
I do this with my headlights etc. If one goes out I replace them all as I figure the others are not far behind. Allen
Old May 23, 2004 | 01:49 AM
Car: GTA 89
Transmission: TH700
The car now has 65 tmls, six of the injectors are the grey/silver ones (Multech ?) and two are black/blue.
I've decided to relace them all, just to be on the safe side
Thanks for help!
Jens
Old May 23, 2004 | 09:52 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
good decision. the multec injectors suck.
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
