Cam logic, questions, and options for 383
Car: 88 Trans Am
Engine: 5.7 TPI
Help me find good numbers for a cam. Take power and streetability into account. My car is driven very hard, but still sees around 1,200 miles a month.
I am having a 383 roller with forged internals built. I have slp cold air, 58mm tb, ported superram and mainifold, nice afr 195 heads, 1.6 rr's, eldelbrock long tube headers, 3" exhaust.
From my general reading and research, I've come to find out that:
-duration is the rpm peak hp will occur (on a 350) 220 = 5500; +/- 10 = +/- 500rpm.
-Lift is more important than duration because it has a direct effect on torque at any given rpm.
-superrams are good up until 6k rpm
-for every 25 additional ci, add 5 to the duration to make power at the same peak. SO in a 383, to peak at 5500 would require about a 226 duration.
-lower lobe seperation = more power, but worse idle.
QUESTIONS:
-I can understand how cam lift and head flow work together, but how does rpm come into the equation? What makes the difference at what rpm the peak power is at? Is rpm related to lift at all?
-Single pattern or dual pattern? Which one is better for this setup.
-I already have a lpe 219/219 .560/.560 112; I see lots of cams with better durations, but the lift (important) is always lower. So should I just stick with this cam?
-What's the intake/exhaust ratio mean? I remember hearing about something to take into consideration if the ratio is at 80% or better (which mine is), but I can't remember what.
Here is my head flow. Notice that from .550 - .600 it flat lines, but doesn't lose power. Would having a lift of greater than .550 be a waste? Or would it be better because it gets to see a constant high flow for longer?
Thanks!
QUESTIONS:
Thanks!
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Running that 219 cam with a 383 and with those heads will really be a crutch on those heads and their abilities. I know that it has about the highest lift for the smallest amount of dur. for a hydraulic roller, but that little bit of lift does not equate to having between 10-16degs more dur. when talking hp. The superram should be ported immensely also to get it somewhere near those head flow numbers. Only ported SRams make peak power at around 6k.
I'd recommend calling Comp and having them grind you a custom cam on a 112 LS at either 230/230 dur or 236/236 dur. The lift on the XE lobes is as good as you'll get for a HR cam. If it's not enough go with a SRoller. If your head flow is above 80% you should run a single pattern cam like the ones mentioned.
One more thing, where did you get those heads ported? And were the exhaust #'s attained with a pipe?
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Everybody will tell you to get a bigger cam, but those that have used the 219, 383, superram combo will tell you that it is the best compromise of power, torque, driveability, gas mileage and emissions.
Other cams will make more power, but at a sacrifice. My combo peaked around 55-5700. You must remember that you are limited in airflow to the heads by that intake, so you must take advantage of the ramming effect and the short duration, high lift of that cam and intake combo. I ran several cams on engine analyzer, and the 219 made the most avg hp and tq with good vacuum. That's why I picked it. It doesn't really lope either.
The only real way to know is to run the 219, then swap to another cam and see the difference.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Car: 88 Trans Am
Engine: 5.7 TPI
camarojoe
The heads were ported by TEA. Stage 1 port. Not sure how the exhaust flow test was done.
The user Johnnyiroc was the one who had these heads ported and tested. I pretty much bought his entire setup off him a few months ago, cam, intake, superram, heads, afpr, injectors, rr's, etc...
He ran a 11.9xx with his 383 and this setup. So, I know that this cam can get me into the 11's...but if I can beat my friend's 11.8 '99 Camaro SS, that would be bad as hell.
What I ment by the superram and 6k is that 6k is pretty much the limit on the superram. Even though mine is ported, I should be peaking a fair bit below that, especially with the lpe 219 cam.
89gta383
Have you ran your setup at the track before? You said your combo peaked at 55-5700. How did you determine that? Have you had your's on the dyno. Johnnyiroc peaked at 4950.
formularpm
So are you saying that even if I got a custom grind, that I would either have to choose big duration or big lift, but not both?
You said not to worry to much about peak lift because the valve spends most of it's time at mid-lift. If I had a lift of something close to .600 though, wouldn't my mid-lift then be raised and I would get better flow?
89gta383
formularpm
Car: 91 Z28
Engine: Forged 383
4mul8r, I figured your heads were ported at TEA as they get better #'s than most porting companies. I know, cause that's where the heads I run got ported. I posted my flow #'s a while back, they were similar on the exhaust as yours.
There's nothing wrong with the 219 if you want brutal low end tq. But you could go with a little bit bigger cam to pull your power band up. Heck you could just retard the 219 cam 2 degs. like Todd85 does with his SR/383/219 setup on his vette. I think his hp peaks at 5600 this way and he's running 11.60's at 117 in his 85 auto vette.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
LT1Formula
Aug 20, 2015 09:36 PM
