Will this cam work?
Old May 29, 2004 | 01:31 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Will this cam work?
I can get this cam for free and need to know if it will work. Im not very good at understanding how cam specs translate into power/drivability etc. so I need your opinions.
1991 Camaro Z28 355CID Auto ((700-R4 with 2600 stall))
Accell 58mm throttlebody , Edelbrock runners , Edelbrock base , Accell 24lb injectors , Holley AFPR , Crane 1.6 Gold roller rockers , Edelbrock Performer heads ((64 CC)) , Edelbrock TES headers 3" no cat exhaust , cars running 9.8:1 compression. The cam thats currently in their is a Comp Cams 08-410-8 (( I know....but it was free)) http://www.compcams.com/Technical/Cu...ML/JPG/142.jpg and I got 263rwhp on the dyno on the stop chip with timing at 8*. I want to hit 300rwhp cause this is my daily driver. Now the cam I can get is 08-305-8 http://www.compcams.com/Technical/Cu...ML/JPG/146.jpg
This is somewhat similar to a custom grind in my buddies 383CID that put down an untuned 367rwhp with A/F in the mid 9s. Will this cam work and are my chances of hitting 300rwhp realistic with tuning and cam swap??? I appreciate any help, suggestions and opinions. Thanks alot guys.
Old May 29, 2004 | 04:07 PM
BadSS's Avatar
That cam would be hard to beat for the money!
Seriously, the difference in the cams would be be around 25 peak rwhp and about a 600RPM higher shift point - definitely "better" than what you're running right now. Plus,,, it's not a bad choice to begin with. Certainly what ever small difference in power you would see by running a cam with different specs,,,, sure wouldn't be worth the money!!!!!!!!!!!!!!
Old May 29, 2004 | 04:37 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
After the cam then it gets tuned cause the AFR was running in the low 10s. I just wanna make sure that there is no glaring problems
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
