87 and 89 Fuel tank sizes and shaped??
Old Jun 5, 2004 | 01:34 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Is the tank the same or not and how about the fuel pickup lines in the tank?
I recently replaced my fried sending unit with an 87 Tpi unit. Today when i took the sharp right turn the engine cut out like the fuel pump wasn't picking up and the gauge showed very close to empty. So i filled up and i only put in 41 liters of gas.
That would indicate that there was still 20 liters left. (4 gallons).
My question again is:
- could the tank be different shape or depth and the fuel pick up in too short
- and does it matter which way the filter at the bottom of the fuel pump is located
Any suggestions welcome.
Old Jun 7, 2004 | 06:25 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Looked at a couple senders from different years, all look the same. There is a tab that locks in the sending unit, can't get it in wrong that I know of. Not sure if there is a different tank size, could be. Odd shaped tank but the lower section is smaller so you shouldn't get the loss of suction with four gallons still in it I'd think. My 88 doesn't hold very much gas for sure, Fill up when near empty is about 10 gallons. Guessing a 14 gallon tank. Kind of unhandy to fill up so often but I get decent gas mileage so I'm not complaining.
mustangman65_79
Apr 14, 2017 05:37 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
knight72
Aug 10, 2015 09:32 PM
