car runs 50 mph by itself...
Old Jun 8, 2004 | 06:50 PM
dailydriver's Avatar
'89 iroc 305 700r I have replaced the iac, tps, and maf sensor...i cleaned the butterfly assembly and the iac port...tps is set at the correct voltage...This problem comes and goes but here lately is more often...car idles (in park) at 2500 rpm...in drive stopped at about 1200 rpm...sometimes however the car runs perfect, idle in drive at about 600 rpm...some times i get a maf code (check engine light)...could i have bought a bad maf sensor?...it came from advance auto...also, if i unplug the maf the car idles correctly (but it smokes)...any suggestions??..this problem started about 2 weeks after i replaced the above parts
Old Jun 9, 2004 | 02:38 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: car runs 50 mph by itself...
Yes you could have gotten a bad MAF. Also, there are certain kinds that wont work well in our cars. Cant remember which brand though. Do a search and you should find it.
B_Dubya
Aug 26, 2015 05:09 PM
kyleb24
Aug 15, 2015 08:24 AM
dhonda200
Aug 11, 2015 11:50 PM
Kaweh
Aug 9, 2015 02:54 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
