Fuel Pump/Relay question
Old Jun 8, 2004 | 09:48 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Should the FP relay activate the pump to prime the fuel rails everytime you cycle the ignition key without starting the car or is there some wait time?
Old Jun 9, 2004 | 08:07 AM
S10Wildside's Avatar
The ECM will not prime the fuel pump every time on the MAF system. I seem to have noticed that the speed density ECM turns the pump on for a few seconds with the ken in ON every time. Could be wrong. But I'm postitive that the ECM does not prime the pump every time for the MAF system.
Old Jun 9, 2004 | 01:03 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Can anybody with a speed density setup verify this?
Scott
Old Jun 9, 2004 | 02:41 PM
I say this because when I started making MAF harnesses, it seemed strange that the fuel pump did not always run when I turned the key to 'run'.
If I wasn't so sick with a nasty cold and sinus pressure, I'd go down to the garage and verify this.
Old Jun 9, 2004 | 03:04 PM
broken305Z's Avatar
Car: 91 Z28
Transmission: 5speed
yup, fuel pump primes everytime I turn the key
Old Jun 9, 2004 | 04:49 PM
Dr G's Avatar
The fuel pump audibly primes each time I turn the key on my MAF car. You should be able hear the buzz/whirr noise of it priming for the first 2-4 seconds after turning the key.
Old Jun 9, 2004 | 07:52 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Thanks everyone.
Take a claritan-d (sp?), work wonders on colds and sinus stuff
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
