good cam for L98 TPI?
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Just want to solicite an opinion on CompCams CS268AH-14.
268/278, 222/226 @ 50, .464/.464
114 seperation
350, stock TPI, L98 aluminum heads, shorty headers, T5 tranny, 3.73 gears, Monte Carlo SS, diy prom (MAP system)
I want to know if I'll be happy with this cam's behaviour on a 350 w/TPI?
My gut feel is that it's too big. I like my motors to have great torque off-idle. I'm not into racing, just like to cruise around and blast from stop lights and such.
Thanks.
Suggestions for alternate non-roller cams appreciated as well.
114 seperation
Thanks.
Suggestions for alternate non-roller cams appreciated as well. Supreme Member
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
IMHO that cam is to big for a stock TPI. Did your 350 block come with a roller cam because the cam you quoted looks like a flat tappet cam? I would call comp cams for the recomendation. I would think you need to back off the duration about 10 degrees. Allen
Engine: 5.7L TPI
1989GTATransAm:
Yes, it's a flat tappet cam I quoted. My engine block is not setup for roller cam.
Thanks for the suggestion and opinion.
I think the one I want might be something like the XE256H-12. 212/218 .449/.456 112 (flat tappet)
EdB
EdB
Engine: 5.7L TPI
Shameless plug...
If anyone wants to buy the CS 268AH from me, here you go:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...tem=7905024601
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
