Mass airflow sensor
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
Mass airflow sensor
Alright, read something somewhere that said not to just unplug and take out the current one and replace because something would get messed up. Is this true at all? I need to check if mine still has screens so I can get a new one without paying core charge. Also curious for when I put in the new one, thanks a ton.
Also, will anything need to be done with the computer?
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
nothing will happen to the new one but you should reset your computer by disconnecting the battery for about 5 minutes when you put the new one on
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When they said not to unplug it, I believe they were referring to unplugging it with the engine running. That would cause some problems.
efiguy
Sep 27, 2015 01:30 PM
