just new heads or a whole new engine?
Old Jun 15, 2004 | 05:46 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
actually my setup is a 305 TPI with the dual cat, borla catback and a vortech s/c
After reading many posts about gaining hp I'm still not sure if i should take some new heads for the 305 or buy a 350 engine.
the actual engine has 65kmiles on it and the last ~5kmiles were with a Vortech s/c.
it is leaking oil since the first mile with the s/c on it and i think it will need a rebuild after tearing the s/c down.
I'm looking to be in the 300-320hp (flywheel) range.
what would you do and what parts would you buy?
Thanks alot for the help
Pat
Old Jun 15, 2004 | 08:44 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Those HP numbers with or without the vortec?
Old Jun 15, 2004 | 09:51 AM
Car: '91 Z28
Engine: LB9
it was before the install
Old Jun 15, 2004 | 09:53 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
I'd have to say get a 350 shortblock with some decent heads like trickflows. Then put the 305 tpi on top of the 350 with 24lb injectors without SC but with SC 30 lbs. with SC should be in the low 13s. depending how many pounds of boost id say 12 lbs of boost would put you in the 12's. just my opinion later man.
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
