broken maf
Old Jun 16, 2004 | 02:57 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
broken maf
hey i got a 89 iroc 350 tpi would the car have a crappy idle if the maf is bad
Old Jun 16, 2004 | 08:37 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That would be one of the symptoms yes, but does not mean the MAF is the problem. Are you getting any trouble codes in the computer.
Old Jun 16, 2004 | 12:15 PM
3.492rs's Avatar
Car: 89 IROCZ
im getting a code 36 maf (i think) and the idle is very horrible, im also getting code 14, 32, 46
Old Jun 16, 2004 | 12:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are having fun with it then aren't you? Here is what your various codes mean.
Code 14 = Coolant Temp Sensor Circuit (High Temperature Indicated)
Code 32 = Exhaust Gas Recirculation Circuit.
Code 36 = Mass Air Flow (MAF) Burn-off circuit
Code 46 = Vehicle Anti-theft (VATS) System
Old Jun 16, 2004 | 01:13 PM
3.492rs's Avatar
Car: 89 IROCZ
so thats causing my very crappy idle it needs a tune up also
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
