intake intake gasket
Old Jun 20, 2004 | 11:31 AM
DRENNON's Avatar
Milled heads .030. Can I use a set of 1/8" intake gaskets and should i use the cork seals on the front and back or just a bead of silicone on the tpi intake gasket?
Old Jun 20, 2004 | 09:35 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: intake intake gasket
If you do not use the cork seals on the china walls you will have to use the silicone (or whatever your using). Make sure you have a big enough bead or you will have a leaking intake. Not sure if you can use the 1/8 gaskets. I wouldnt see why not though.
Old Jun 20, 2004 | 10:14 PM
DRENNON's Avatar
Thanks for the info. CapTPicardsZ28.
I will use the 1/8" intake gasket with a 1/4" silicone bead on the china walls.Unless someone else thinks I should use the cork.
Old Jun 21, 2004 | 09:43 AM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
I used RTV Black on my China Walls. Use too much rather than too little. Make sure you go up the ends where it mates with the intake gasket.
Old Jun 21, 2004 | 12:08 PM
DRENNON's Avatar
JA_Formula_&9
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
