HSR and a Nitrous Fogger Set Up.(anyone Have Pics)
Old Jun 26, 2004 | 04:26 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok I posted this on Stealthram.com and no one replied. so here we Go.
has any one on here had their HSR drilled and tapped for a Fogger nitrous system. If so Do you have Pictures
I tend to lean towards a fogger set up over a Plate set up and Eventually I will be running a HSR (probally next year) When I order the intake I will order it directly form Holley with a Direct Port Sportsman Fogger so that they can drill and tap and set everything up on it. I just wanted to see it anyone else has pictures or has done this.
Old Aug 9, 2007 | 01:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: HSR and a Nitrous Fogger Set Up
Old Aug 9, 2007 | 01:19 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
holy completely different engine and engine bay batman. What engine/bay is that of?
Old Aug 9, 2007 | 06:09 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
its a newer gm something, cant really tell. sorta looks like a 5.3 in a 1500? no clue
Old Aug 9, 2007 | 04:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
96 Impala SS. its a LT1 motor but with HSR. AFR LT1 heads have been modified to accept HSR small block bolt pattern. its got a fogger system drilled/tapped into the runners, as well as another fogger spray bar system inside the plenum
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
lakeffect2
Aug 23, 2015 08:44 AM
89lsc
Aug 14, 2015 04:58 PM
BrianI
Aug 9, 2015 11:52 AM
