intake leak?
Old Jun 26, 2004 | 06:42 PM
DRENNON's Avatar
intake leak?
Just changed cam from Eldelbcock RPM to Comp 206 int 212 ex.
Car runs fine after adjusting accel ecu The problem is the vacuum is only about 4" or 5".Looks like a bad intake leak.What is the best way t check for this. This is a 350 with a tip setup and a standard tpi ntake with a Elderbrock runners.Never checked the vacuum with the RPM camThanks
Old Jun 26, 2004 | 07:14 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
The best way and probibly the safest is to take a propane tank with a hose atached. Work the tip around the intake. When your rpm's drasticly increase, you've found your leak.
or
You can always use a can of carburator cleaner, but this way isn't the safest.
Bill
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
