Aftermarket Pulley's for removing A.I.R
Old Jul 8, 2004 | 08:34 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I would like to remove the emissions, but I don't want to put something in it's place...aka the smog pump delete pulley.
I was looking at street and performance style pulleys, but I was unsure of which ones that I can use. I am looking for a serpentine system, but I would also like it easy to work on.
Anybody got any ideas and web pages so I can look at some of them?
Old Jul 8, 2004 | 08:53 AM
What about the one at the top left?
http://www.hotrodlane.cc/onlinecatal...logpage21.html
Old Jul 8, 2004 | 12:19 PM
age's Avatar
age
Car: 1992 Z28 1LE
have you tried rerouting the serpentine belt on your setup?
Old Jul 8, 2004 | 05:01 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
rip out the guts of the pump and re-install it. You now have an AIR pump delete pulley.
Old Jul 8, 2004 | 05:03 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
That's what I did, pump was unhooked and making all kinds of racket:
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Jul 9, 2004 | 08:23 AM
That's kind of the thing, I don't want anything there at all. It is to packed underneath the hood, and it's an eye soar.
I haven't tried re-routing the belt yet, but I have read that it doesn't work to well with the distance from the crank pulley to the alternator. It gives the belt a lot of 'slap' for the slack that it has.
Old Jul 9, 2004 | 05:25 PM
age's Avatar
age
Car: 1992 Z28 1LE
maroon: I have the March Power and Amp pulleys, no AC, no AIR pulleys. I reused my original sized belt (pre-aftermarket pulleys) and rerouted my belt. It worked fine.
Old Jul 12, 2004 | 04:29 PM
Noted, thanks.
Old Jul 12, 2004 | 07:42 PM
25THRSS's Avatar
Smog pump delete pulley part # 10186167. Looks a lot better than an empty gaping hole, you can retain all of your bolts holding the brackets to the block, and you don't get any slop in the belt.
Old Jul 12, 2004 | 11:56 PM
Yeah, but I would rather have it empty and look like and engine, than a rubbered hose piece of iron.
Old Jul 12, 2004 | 11:58 PM
25THRSS's Avatar
I think your best bet would be a custom setup like something march makes.
Old Jul 13, 2004 | 08:18 AM
Do they make regular pulleys, or are they all the underdrive ones?
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
