Dyno2003 Help, TPI cfm flow...
Old Jul 13, 2004 | 02:06 PM
92GTA's Avatar
I'm doing a mock up of my engine and Dyno2003 needs to know TPI cfm flow @ 1.50 inHg.
I've got a TPIS 52mm TB, Air Foil, stock plenum, SLP runners, and an Accel base. All of them are port matched to each other perfectly.
What would you guess it would flow?
Thanks!
Old Jul 13, 2004 | 03:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'll take a wild guess and say 225 CFM. I have seen where the stock ACCEL base flows 251 CFM. The ACCEl cast LTR flow at 242 CFM and I believe the SLP may be slighly less. So all bolted together with the stock plenum is my guess of 225 CFM.
Allen
Old Jul 13, 2004 | 06:07 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Umm, no, the induction flow they're looking for is at the throttle body, not the intake manifold. Guess around 850-900 cfm with the 52 MM throttle body. (though your intake tract before the TB could lower that)
Old Jul 13, 2004 | 06:26 PM
92GTA's Avatar
Thanks!
The default value Dyno2003 put in there was 300 so I kinda thought
1989GTATransAm wasn't too far off there but it makes since that they would want the TB air flow, just like a carb cfm air flow you know. I put in 850 and the power curve looks a little more "realistic" now...
Old Jul 15, 2004 | 08:12 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
48 mm - 630 CFM.
52 mm - 750 CFM.
formula_novice
Sep 5, 2015 03:58 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
