Converting from tbi to map tpi
Car: 88' Iroc-Z
Engine: LQ9
I'm looking to convert my 88 iroc that came with the 305tbi motor and replacing it with a 355. but i'm going to a 4 barrel intake and 4 barrel throttle body with the intake drilled and welded for injectors. What I'm trying to figure out is, What do i need to go from tbi to map tpi? I already have the 730 ecm. do i need an entire harness? would that be easiest?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Converting from tbi to map tpi
ANyway, just need to repin your harness, and add the injector connectors.
Do a search for a thread by me. I did a writeup on the conversion.
-- Joe
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
