power guesses on my new 383
Old Jul 21, 2004 | 06:04 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
It's been about a year since I posted here but I have my new motor ready and I'm eager to try it out! I get the chance in 2 weeks.
Any power guesses?
383 stroker, late 4-bolt roller
block honed, deburred and screened oil galleries, fluxed/tanked
HT383 3.8" stroke 4340 crank, 4.0" bore
moly rings
4340 I beam rods
dished HT383 pistons, hypereutectic (special)
cc306 cam
1.6 NSA pro mags, 7/16 studs
Comp 977 springs and AFR rev kit
Lloyd Elliott converted LT1 heads, fully worked (11.5:1 CR)
LT1 ported intake
double roller timing chain
new HP melling oil pump with shimmed relief spring
stock HT383 windage tray
hedman longtube headers and borla catback
58mm BBK TB
A/C delete, high flow aluminum water pump
no tune yet, running through modded MAF TPI
will be running through a T-56 and 12 bolt
I know the headers are small but they're what I have, and I'm considering an LS1 swap before I buy a crossmember and another set of headers...I figured it was time to get the damn thing done after 3 1/2 years of changing my mind! Can't wait to drive my car after 4 years!!!
A couple mags did some lower CR testing on the HT383 and got 500 ft.lbs and like 460 HP. I'm sure I'll be a little lower, I just want torque mostly for now. Any guesses?
Old Jul 21, 2004 | 08:59 AM
Mesix's Avatar
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
I'm gonna take a shot in the dark and say around 450
Old Jul 21, 2004 | 09:33 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i would say 460-470 range but man that thing is going to rip.
Old Jul 21, 2004 | 09:46 AM
1981z28's Avatar
hmm
450-500hp with close ft.lbs
thats very close to the way i got my 383 set up and i only have 450hp but i have 500ft.lbs
Old Jul 21, 2004 | 05:33 PM
dhirocz's Avatar
That was my guess. I would have went bigger with the cam but with the runner size of those heads and since I'm still using that damn MAF I figured it wouldn't make too much sense. At least this way it'll be fun as hell to drive out of a corner!
Old Jul 21, 2004 | 10:41 PM
Cali Z's Avatar
what's the 1/4 worth?
This thing sounds like a monster! It should be capable of getting into the 11's right? I think all this waiting is sure going to pay off extremely well. Good luck to you and your new awesome engine.
Old Jul 22, 2004 | 08:34 PM
dhirocz's Avatar
I'm guessing mid to low 11's naturally aspirated on drag radials. Later if I choose to spray I'll have some custom pistons made. I'm going to a 12 bolt because I want to be able to run drag radials and/or not have to worry about grenading the rear. In any case, the motor is set up pretty much for cornering, has alot of weight reduction, and should be a blast.
Old Jul 24, 2004 | 04:54 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I couldn't find your cam listed on Comp Cams website. So I don't know the specs. I find 11.5:1 CR hard to believe with dish pistons but I'll take your word for it. I got 461 HP and 507 TQ using desktop dyno with my cam specs.
Old Jul 24, 2004 | 05:06 AM
dhirocz's Avatar
it's known as a cc306, but I dont remember the comp cams part number. it's a 230/244/112 with .510 and .540 with a 1.5 rocker (I have 1.6). The LT1 heads I chose because they were aluminum, flow well when ported, were cheap, fit the LT1 intake bolt pattern, and have small combustion chambers to match my dished pistons which are like a -18cc dish. I run a .015" head gasket and the heads are further machined to be smaller. It's between 11.3 and 11.5:1. My castings were thick so they were able to be ported a little more. I have maybe $120 in the heads and intake which includes comp 977 springs, retainers, 10 degree locks, ferrea 2.00/1.56" stainless valves, 7/16 studs and machine work.
With the small runner heads and that cam in the 383, it should be a damn good midrange engine easily capable of low 12's on street tires, mid 11's on drag meats with *** driving and 10's on a small shot of N20. I figured it made no sense o go with a bigger cam since I'm running on the ragged edge of the limits of MAF TPI anyway. At least the car is light as hell I just wish I knew how light.
Old Jul 24, 2004 | 09:51 PM
89Warbird's Avatar
Engine: 389 CID TPI
Okay, with your cam specs 464 hp and 504 tq, but it is dependent on what the heads truly flow. If they can flow as good as a set of AFR's it shows 490 hp and still 504 tq. So, it's how good are your heads ported. Large tube headers only showed a 8 hp gain.
Old Jul 24, 2004 | 10:42 PM
dhirocz's Avatar
Sounds awesome. Lloyd say they flow in the 270+ range since they were thick and could be ported more. PRobably flor about 190 on the exhaust side. I think what hurts most is the fact that the headers are hedmans so they're only 1 5/8 longtubes.
Nice thing about this motor is it only cost me maybe $2500 including the bottom end. I need to get a chip burnt still though. I'm pretty sure it wont run on a stock 89 TPI tune.
Old Aug 10, 2004 | 02:00 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
Nice motor
with a 4.10 in the 12 bolt and you shift like money that thing is going to fly
Good luck, and kick some **** with that thing
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
