Weird hissing
Old Jul 23, 2004 | 01:55 PM
Mesix's Avatar
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
Weird hissing
I knew I had a bad thermostat gasket, and it was making the engine overheat really bad. So I changed that last night. No more overheating. But I was out driving today and I hear the same periodic hiss that I though before was coolant hitting the block. I know the seal is good now, as my cooling system works very well. Never over 200. It smells faintly like coolant, but thats probably from before, it's not really obvious now. Any ideas what this hissing is?
Old Jul 23, 2004 | 02:04 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
just a thought, but have u had your ac on? could it just be condensation hitting the manifolds?
Old Jul 23, 2004 | 02:33 PM
Mesix's Avatar
Car: '87 Trans Am
Transmission: M5
The A/C doesn't work, so I keep it off. It's needs a charge, but at the moment I know thats not it.
Old Jul 24, 2004 | 11:44 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Have you checked the circulation of the coolant after installing the thermostat? Open your radiator cap when the car's motor is cold and watch the circulation of the water/coolant. Also did you make sure your thermostat was positioned correctly? These are just a few thoughts from past expieriences.
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
