changing trany in my camaro need infor about flywheel?
Old Jul 23, 2004 | 09:07 PM
V6camaroman's Avatar
ok i have my 85 z28 with the 305tpi in it (in sig). its got the 700r4 in it thats on its way out. i have another good 700r4 from an 84z28. im gonna do some small mods to it before i put it in but my ques is what flywheel do i have in my car? a 168 tooth or a 153 tooth?
Old Jul 23, 2004 | 11:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
153 tooth is what should have come in your car.
Old Jul 24, 2004 | 04:13 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
You can change your flexplate to a larger racing type flexpalte offered on ebay. But for it to work you will need a mini starter or a starter that has dual mounting hole options to accomadate for the larger diameter flexplate. Believe me changing to one of these will save you some aggravation and frustration in the future. The stock flexplate has a very nasty reputation for cracking around where the bolt holes are. Mine cracked all the way around full circle. The flexplate I bought was a Scat same people that make the Scat Crankshafts.
Go to ebaymotors and do a search for Scat Flexplates and you won't be sorry.
automatic transmissions use a "Flexplate".
Manual Transmissions use a "Flywheel".
Good luck with your swap!
Old Jul 24, 2004 | 09:57 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
fly wheel
If your getting jegs or summit just get any 153 tooth flywheel that is SFI approved and the plate will be twice as thick as the factory one. I busted mine twice in one year when I got a a 24 to 2600 stall being pushed with a stroker shatters a stocker.The stock plate looks 1/16th thick and any SFI approved is going to be atleast 1/8th thick and probably a stronger metal as well.
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Zachattack0925
Aug 12, 2015 09:52 PM
