lt1 cam?
Old Jul 27, 2004 | 04:17 PM
thirdgenner05's Avatar
Car: 89 t/a
lt1 cam?
alright Ive searched the boards but have not found someone in the same sit. as me. I have an 89 lb9 ta with full exhaust work. Im about to install a fully ported tpi intake setup which is claimed to be able to support a 383. I can get a lt1 cam for 20 bucks, later this summer I want to do either ported heads or just buy new ones and a 2000-2500 stall tq. conv. do yall think this cam swap is efficient or not. most people wanna run the stock heads with the cam or wanna put a tq conv. with the stock cam, Im replacing it all so let me know, thanks guys
Jason
Old Jul 27, 2004 | 07:24 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
your doing what ime doing
i also have 89 lb9 with full exhaust as well
i have both a 97 lt1 cam out of a ws6 and rebuilt 305 081 castings with a valvejob and i will be porting them coming soon
i already have a built trans wih a 2500 converter and 3.73 rear and will be porting my stock tipi for right now
and yes the lt1 cam is a great upgrade for a lb9
stock peanut cam is .350 intake and the lt1 is about .450 which is sweet when you can get one for so cheap
it also idles stock and works well with tpi rpm levels
Old Jul 27, 2004 | 10:34 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Same thing I'm doing, except I'm going with an LT1 intake as well. I'll more than likely have 3.73 gears by the end of this week or early next week, and I'll be swapping the cam in when I get the intake. I don't have headers, so you guys will probably feel a bit more of a gain than I, but I do at least have a 3" exhaust. I'm also planning on porting the stock heads, but probably not until the winter when I have a second car, at which point I will get 1.6 rockers, new springs, and a complete 3-angle valve job. A stall converter is also in my plans, but I don't know if I will do that this summer or over the winter (I'm not sure if I'm going to drop a 355 in yet with my 305 heads and LT1 intake).
I'm hoping with this setup to get into 13's, and I don't see why I couldn't assuming I get a set of headers and burn some chips.
Old Jul 27, 2004 | 10:48 PM
jerflash's Avatar
i heard from alot of people that the lt1 on the 305 even with the lt1 cam gives up to much torq and goes not give enought up to to warrent the swap
thats why im porting my stock peices for now until i can get some runners and base
but with ported heads it might not be that bad
if you want i will give you the heads off of my car when i change them
Old Jul 27, 2004 | 10:59 PM
Car: 89 t/a
is that just stock 305 heads?
Jason
Old Jul 27, 2004 | 11:04 PM
jerflash's Avatar
well i was just offering them so he could port them and not have any down time on his car because thats what im doing
the heads are good just need valve seals
081 castings
Old Jul 28, 2004 | 08:55 AM
Car: 89 t/a
well I just found out that I have a cracked o ring. Seems Im not gonna put that cam in the 305 but just scrap it and throw in a crate 350, just have to find the cash.
Jason
Old Jul 28, 2004 | 10:49 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
there's a few people running the LT4 hotcam too...that, i'd like to hear.
Old Jul 30, 2004 | 05:56 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
The cam I'm running is actually an LT1 Grind cam. It runs very very well!
Old Jul 30, 2004 | 06:30 AM
vwdave's Avatar
I have a LT4 Standard in my 350, It runs very well. I donno how it improved the car since I put it in when I did the 350, and the TPI was installed later. Really strong from 2000-5200 RPM's.
Old Aug 1, 2004 | 09:32 AM
Coop91SRS's Avatar
Car: 1991 Camaro RS
Transmission: 5-SPD
Thats whats kinda got me in a bind.. the LT4 prod cam at 203*/210* is just about the same as an LT1 prod cam at 201*/208*.. and lift is much the same.. and both do really really well in the motors they cam stock in. Personally I think adding one of the cams to a 305, as most people are doing and say to do these days, is going to do what I felt my old L98 cam did.. put the powerband way to high up in the RPM range. The ol' l03 was still pulling good at 6k when I really had no business there, especially not with a street car... and not considering the seemingly known fact that TPI isnt ment for high RPM.
But as always.. just my opinions
Old Aug 3, 2004 | 07:42 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have a lt1 cam in my formula it is a great upgrade for low bucks. I like mine alot, with my setup. See sig.
Old Sep 20, 2004 | 04:46 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I have a 87 iroc auto with an lb9. I want to put a lt1 cam in to replace the penut cam thats in it now I have full exhust in this car and 3.23 gears. I don't want to change anything in the ecm, so i would like to know if anybody Knows how a mostly stock lb9 would act with a lt1 cam?
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
