Overheating really bad...
Old Aug 2, 2004 | 01:16 PM
HoustonL98's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 5.7TPI
Transmission: TH700R4
It has a new water pump and I just boiled the radiator out but its still overheating, although it improved a little. It is starting to get worse. I am right in thinking it could be a bad fuel pump? As every day passes I lose more power. It overheates more and more and it takes longer to start. I have been told an extremely lean condition could cause overheating. The overheating is weird too. Dropping it in neutral and revving it does nothing but make it heat up more. Driving on the highway makes it overheat like a ****...heats up less at a stand still. Please give me some tips!
Old Aug 2, 2004 | 02:31 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
1 check the air dam that bolts under the radiator if u are missing that it could cause over heating problems.
2 if u think its the fuel pump check the filter and relay for the fuel pump before u do anything else
Old Aug 2, 2004 | 02:59 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I don't think a fuel pump is going to casue that type of overheating. Not to say it may not be bad, but I would look at the more obvious stuff. If you put in a new pump, you sure its the proper one for your car and not a reverse rotation or anything. Also look at replacing your radiator. After 15 years they get clogged and break down. Thermostat working? Any hoses getting pinched or leaking from age? Is your coolant temp sensor working? Fans coming on?
Old Aug 2, 2004 | 03:32 PM
HoustonL98's Avatar
Engine: L98 5.7TPI
Definitely correct pump. Fans work fantastic. Radiator looks almost new. It looked clean on the inside before I boiled it out and now it looks brand new. I inspected each hose and each is in very good condition. I checked the flow of coolant throughout the radiator and engine and it is good and steady. I did this by disconnecting the a single hose at a time while the engine was running. When the guage reports that it is overheating bigtime I will open the hood up to find the overflow tank about to overflow. It is definitely overheating. The coolant system is definitely working.
Old Aug 2, 2004 | 04:13 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Is your radiator cap holding the correct amount of pressure?
Are you getting any trouble codes? If you were running lean enough to make it that hot, you would throw a code.
Old Aug 4, 2004 | 11:38 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Check your timing. Also, make sure your balancer ring hasn't slipped, which would cause a false timing reading. I've been there myself with the overheating.....I brought the #1 cylinder to TDC on compression stroke and found my balancer ring had slipped 35 deg, so my timing was retarded by that much....I had horrible driveability and overheating problems. Check these things.
Old Aug 5, 2004 | 05:21 AM
contactpatch's Avatar
Engine: sbc 350
Houston, did the car ever have Dexcool
for collant?
Old Aug 7, 2004 | 01:33 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Gee..For the fluid in your tank to expand so much its overflowing is a problem. What everyone else has mentioned are good places to start for overheating stuff.
First, are you leaking any fluid? Any place in the system where there a loss of pressure could definately reduce the boiling point of the fluid, causing you to boil over that much faster. You say it has a new waterpump; did you install it? Check around it for leaks. Do you smell burned/hot coolant? Any steam escaping from anywhere?
Check for leaks and go ahead and get a new radiator cap. Might as well replace your thermostat and gasket also, as that could be the source too.
And the obvious, is your airdam there? And is the black plastic shroud that slopes down the front of the condenser and connect to the underside of the front lower spolier intact?
I live in Dallas, and keeping it under 220 in traffic is nill in the summertime.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
