Which injectors for my bro's 92 Firebird?
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
OK, car is done but I need to get new injectors because the car is running way too lean. I need to know which injectors to buy for it. Right now we are running the stock injectors and that just isn't getitng it done. Guy burning the chip ran all the tests on it and says it needs new injectors.
Car is a 92 Firebird with an 87 TPI swapped in. upper manifold and plenum, etc has been redone and ported, heads have been redone, bottom end rebuilt to stock. Cam is a Comp Xtreme Energy cam, 268/280 advertised duration 224/230 at .050" .477/.480 lift 114 cl. Those specs are with 1.5 rockers, we are running 1.6s.
I need some part numbers, etc. Or even some good used ones that I can drop in the car. Anyone have anything?
New2Chevy
Oct 4, 2015 11:27 PM
