Rear plenum seal...
Old Aug 5, 2004 | 12:40 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Rear plenum seal...
I have always been a carburator guy and just bought a TPI daily driver. The rear intake seal seems to be leaking oil. Is this fairly common, or should I be looking for somethning else too?
Old Aug 5, 2004 | 06:37 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
It's common. You'll have to take the intake base off to fix it. You'll only get gaskets to mate the heads with the base. For the front and back, use a thick bead of RTV. I like to lay mine on really thick so it comes out when you tighten down the base. After it dries, I'll trim it flush with a razor blade so it doesn't look like crap.
Old Aug 5, 2004 | 07:29 PM
REALPOWER's Avatar
Transmission: Th350
Thanks!
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
