which would would i benefit more from.....
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
which would have better results, buying a edelbrock base manifold for my tpi, slp runners, or a 52mm throttle body?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Base and runners, hands down.
Read <A HREF="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=104116">this thread</A> about larger TB diameters.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: which would would i benefit more from.....
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The whole setup is designed a certian size to go with each piece. Replacing one piece wont effect much.
Headers/Exhaust.... then base/runners...... then cam maybe heads... THEN throttle body.
See my sig, I'm still running a 48mm.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
From the parts you have mentioned I would go with the Edelbrock base. I agree that you should modify your exhaust system first if you have not done so. Allen
i already have headers and exhaust ...i ordered a set of slp runners and soon i will order an edelbrock intake..... thanks for the help
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
