89 gta wont start
Old Aug 10, 2004 | 09:15 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
89 gta wont start
I have and 89 gta 77,000 miles it cranks but wont start it is getting spark and the rail has fuel, no lights on the dash come on when you turn the key forward except the security light and the seatbelt light which turn off after a few seconds leaving no lights on the dash on . when the terminal is jumped it also does nothing. I just replaced the computer about a month and a half ago it looks as if its dumped out again. Any feed back on what you might think would be very helpfull here.
Old Aug 10, 2004 | 10:43 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
i don't know if this will help but when my 87 GTA did about the same thing it was because my ignition module got covered in oil. The car would just turn over and over and over. I put a new coil in the car and it started right up then ran for a bit then wouldn't run anymore. Once I found the ignition module covered in oil I cleaned it off and the car ran great from then on.
Old Aug 10, 2004 | 10:46 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
I would guess you are having a VATS problem.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Winchester1094
Aug 18, 2015 10:23 AM
Street Lethal
Aug 14, 2015 08:25 PM
