Cam Suggestions
Old Aug 12, 2004 | 08:41 PM
Wolfpack's Avatar
Car: 86 Iroc
Cam Suggestions
Im doing a Resto on my 86 Iroc and Since Im gonna have the Engine out for Paint and a T56 Conversion I wanted to Pep it up abit.
Its a 305 TPI with all the free mods, Minor Port work to the Intake(walls, port smoothing etc etc) Headman Headers and Y pipe, High flow Cat, Banks Cat Back(when I get to it), Fuel Presure Regulator, MSD 6 Ignitions System, Gutted MAF, K&N filters, No Smog stuff and will prob be running 3.73 gears in the Back once I get to the Rear of the Car.
Anyone Have a Decent Cheap(cuse I wont reuse it in my 383) Cam that will work well with the above combo...again cheap
Thanks In advance...
Old Aug 13, 2004 | 01:07 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
what kind of power / RPM are you looking for?
Old Aug 13, 2004 | 09:29 AM
Wolfpack's Avatar
Car: 86 Iroc
Its a Street Car so nothing Radical. Something that keeps the Lowend Power but gives the 305 more Mid and Upper RPM pull.
Old Aug 13, 2004 | 07:45 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Look at the LB9 cam out of an 88. It's a roller, but you should also be able to find something similar in a regular flat tappet cam. The key here is that cam has a very large LSA, which reduces overlap and mellows the idle. It pulls pretty good at lower RPMs, I can poke along in 4th gear at 1000 RPM without lugging. I can go through parking lots in 2nd gear with my foot off the gas.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
