Question about vacume lines. Pic inside
Old Aug 16, 2004 | 04:34 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm wondering if these pipe in the pic below should be connected to that small connector? What is that small connector for?
Thanks for any help.
Robert
Old Aug 16, 2004 | 04:35 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
This would help
Old Aug 16, 2004 | 05:16 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
you are correct, im pretty sure it goes there.
Old Aug 16, 2004 | 09:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The item that you are holding in your hand appears to be the canister purge solenoid and that is what the connector is for. If you start having a problem with the engine running at idle. just switch those two hoses around. The item that hose is connected to is the canister purge valve.
Frozer!!!
Jan 19, 2024 04:55 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
