Tpi???
Old Aug 19, 2004 | 09:39 AM
1gta2c's Avatar
Tpi???
What if any is the difference between the 84-88, and the 89-92 throttle body's.
Old Aug 19, 2004 | 11:45 AM
Ruthven13's Avatar
Car: 1991 GMC K5
Engine: 350 TBI stock
Transmission: 700R4 stock
I think it is in the way the throttle cable or something mounts... Otherwise They are pretty much the same... Somebody correct me if I am wrong :lala:
Old Aug 19, 2004 | 12:39 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Throttle cable linkage (84-88 is straight pull, 89+ is radiused pull) is the biggest thing. Get the TB that matches your cable or get the cable that matches your TB.
The IAC passage is also different. In order to use an early TB on a late plenum, you have to drill a hole between the throttle ports on the plenum. Look at the back of the TB and you'll see what I mean. Late TB will work with either plenum just fine.
Old Aug 31, 2004 | 11:06 PM
formulaman's Avatar
They seem to go on ebay fairly cheap
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
