fuel pressure regulator
Old Aug 12, 2004 | 11:13 AM
klystron's Avatar
Car: 87 IROC
Engine: 350cu.
Transmission: 700-R4
I'm looking for the entire fuel pressure regulator for my 87 IROC
350c.u. Everyone sells the kit which is the spring/ diaphram replacement. I replaced that but my pressure immeadiately bleeds
down when the fuel pump stops. If I pinch the fuel return line it
holds. This would mean the seat of the regulator is leaking. Dose
anyone know where to order the entire regulator from?
Old Aug 12, 2004 | 11:59 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The only place that I know of that sells the complete assembly is the dealership and when I bought mine about 5 months ago it was $163.00 + tax (ouch). There might be some aftermarket ones out there somewhere. You could try gmpartsdirect to see if they had any.
Old Aug 13, 2004 | 01:28 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: fuel pressure regulator
Any auto parts store should have them. Last I knew, Checker Auto had them. You can also try these guys. I believe they have them for 70 bucks. Call them:
http://www.hotrodlane.cc/
Old Aug 13, 2004 | 07:02 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have one I was about to drill out and modify for use on my new setup.. If you offered me the right amount, plus shipping, i'd part with it.. Seems as if I need to buy one with threaded connectors, rather than press fit.
-- Joe
Old Aug 31, 2004 | 11:11 PM
formulaman's Avatar
Ebay
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
