looking for cam selection advise
Old Aug 21, 2004 | 11:52 PM
IROCDave's Avatar
Car: 1987 IROC
Engine: zz4 short block
Well the subject line says it all, i plan on swapping cams this fall and am interested in hearring some other opinions.
Here is my current set up- 87 iroc, rblt 700r4 with 2500 stall, 3.42 gears, hotchkis control arms
ENGINE- zz4 short block, old style Trick Flow heads( 1995 vintage) slp t-ram intake, ls1 injectors, 1 3/4 slp headers, slp cat back , random tech cat, 54 mm throttle body, ed wright chip.
Current cam- crane hr-276-2s-12 ig
I=.488, 214 deg @ .050
E=.509, 222 deg @.050
The current set up has run a 13.24 et @ 103 mph ( has been to the track twice, total of 4 passes). When the motor was new it put out 298 rwhp and 362 rwtq, but the af ratio was around 15 to 1.
I built the car several years ago hoping to run mid twelves around 110 mph, but its not quite there. Any suggestions will be greatly apeciated.
Old Aug 22, 2004 | 02:47 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
TPIS ZZ-9X. If you put a stroker crank in it then it would really like it.
Old Aug 22, 2004 | 06:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Your ET seems in range depending on track copnditons. . However your MPH is way low for 300 RWHP. I'am running 102.25MPH with 256 RWHP and a heavy GTA.
Old Aug 22, 2004 | 08:40 PM
IROCDave's Avatar
Car: 1987 IROC
Yea I know the mph was pretty low, thats why im leanning towards a more agressive cam. One possibility for the lack of mph could have been the tempature at the time, about 90 to 95 on the asphalt and the t-ram intake is a giant heat sink. Typically the inlet air temp rises to about 145 deg if not given time to cool wich was the case before each pass. During normal driving conditions (not idling stationary) the inlet air temp stays around 80 degrees.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Strick1
Sep 4, 2015 07:11 AM
