Fuel line fittings...
Car: 1989 Pontiac Trans Am GTA
Engine: L98 350
I'm replacing my rusting lines with aluninum and braided lines. I have figured out how to connect the lines to a stock fuel filter using AN fittings and adaptors...I'm stuck when it comes to connecting the braided line to the intake fuel rails...and the feed line coming off the sending unit. Basically I need: 1 female 16MM that will flair or compress-fit onto the aluminum hard line, and a 16MM and 14MM female that I can attach to the braided line. I've seen guys replaced the rubber hoses up front with braided line...have any of you done it from scratch or did you buy already fitted lines? If they are premade...where can I get them?
Ryan
Ryan
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
this is intended for TBI applications, but I recall seeing part numbers very similar to what you are searching for. hope this helps
https://www.thirdgen.org/techbb2/sho...hreadid=196540
EAR 991954 (-6 to 14 mm adapter)
EAR 991955 (-6 to 16mm adapter)
AFAIK, earls will pre-assemble any line for you.
www.earls.co.uk
www.earls.co.uk
Engine: L98 350
Those earls part numbers are for double sided males...which will work for the fuel filter since the filter fittings are female. The problem is the intake fuel rails fittings are male...so i need 16 and 14 MM female fittings that I can attach to both braided line and hard line.
Ryan
Ryan
Car: check
Engine: check
Transmission: check
Ryan
Ryan
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
RBob.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
