Fuel Pump on a 88 Formula w/ 350
Old Aug 24, 2004 | 05:48 PM
Lime's Avatar
Car: GS
I've found an 88 Firebird Formula with the 350 and less than 100k miles for $1500 b/o and all it needs is a fuel pump. How expensive is a fuel pump and how hard is it to install? This seemed the best place to ask, as it somewhat has something to do with the engine.
Old Aug 24, 2004 | 05:52 PM
JesasaurusRex's Avatar
Not really "hard" just a PITA. Here this will tell u everything u need to do. I dont suggest getting another in tank pump if you plan on modding.
https://www.thirdgen.org/techbb2/sho...ping+Fuel+Tank
Do a search next time homie.
Old Aug 24, 2004 | 06:02 PM
Lime's Avatar
Car: GS
oh, hahah thanks dude. I'm new to the whole f-body scene, and these boards, I didn't know you had a search feature. thanks a bunch dude!
Old Aug 24, 2004 | 06:16 PM
Sure thing
Old Aug 24, 2004 | 06:28 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Mine wasn't hard, took about 6 hours of work, only because I had to drain my tank (I had 3/4 tank when it went out) and the syphone was hella slow. After I dropped the rear down, I pulled my exhaust off at the cat and laid the I-Pipe on the top of the axle, dropping the tank was pretty easy. Putting the new pump in was a piece of cake, come to think of it, the whole job was easy. It would have been rougher if my exhaust was welded all the way (I helped a friend who had welded exhaust, it was a bit of a pita to get the tank to drop)
I did away with the pulsator when I did mine, no problems yet.
Old Aug 24, 2004 | 07:24 PM
Lime's Avatar
Car: GS
While I'm in there, is there anything else i should change? like the fuel relay, sender, filter, etc? Also, how much will all these parts cost?
Old Aug 24, 2004 | 09:26 PM
Well You should replace your Strainer for the pump (some places require it to get the warranty), pulsator, filter, and tank o-ring.
I choose the cheap route for the pulsator, I removed it and used a piece of fuel line in it's place, and clamped it on both ends.
Unless your sender was giving you problems, I would just leave it alone.
I would replace your fuel filter along with the new pump if it hasn't been done in a while, or if you don't know when it was done yet.
The o-ring on the tank should be replaced also, I would definetly go to GM for that part, since the ones that come with the pumps are usually just o-rings. The GM one has tabs on it and seems to fit best.
So for parts... probably around 70 for a generic replacement fuel pump, 140 for a high performance pump. I believe a new pulsator was 22 bux, where a piece of hose and clamps would be a lot cheaper. The fuel filter should be around 6-8 bux, and the tank o-ring can't be more than 10 bux. So anywhere between 108 to 180 depending on what you buy and where you get it.
I didn't replace the o-ring because I was planning on using the one that came with the pump, but it didn't fit, and I had no transportation while my car was down. I also didn't do the filter cause I did it less than 3 months ago.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
okfoz
Oct 13, 2015 02:19 PM
92projectcamaro
Sep 29, 2015 07:07 PM
