How do you check if the knock sensor is working?
Old Aug 30, 2004 | 09:47 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
My scanner does not detect any knock but at WOT I can hear something, how do I determine if my knock sensor is working?
Old Aug 30, 2004 | 11:08 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
1.Get a timing light
2. get a pipe or metal wrench
while motor is idling knock on the motor or block as soon as you make a metal to metal knock or clank you should visibly notice that your timing mark pulls back considerably.
If it isnt working properly your going to tear your motor up. especially if your making considerably more power than stock.
I replaced many head gaskets before I found a bad knock sensor to be at fault.
9192camaro
16
Feb 3, 2019 12:21 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
Newguy91rs
Aug 7, 2015 09:51 PM
