Help with no spark in 5.7L TPI
Old Aug 31, 2004 | 11:45 AM
Night Hawk's Avatar
Hi I'm having a serious problem getting my car started due to zero spark. I have plenty of fuel pressure and I have performed the following:
- Replaced Module
- Replaced Pickup Coil
- Tested the main coil off the vehicle and it gave a nice blue spark snap
- Checked distributor connections
- Checked ECM fuse
Background info:
- Plugs, Rotor, Cap, Wires all replaced about 2 years ago
- Has an older [blue anodized aluminum casing] Crane Fireball ignition box [possible culprit?]
- Fuel pump replaced last year
*** Car was running like new until I went outside one night to head to the bar and there was no spark whatsoever ***
Any idea's? What kind of symptoms would be shown if the ignition box has failed?
Old Aug 31, 2004 | 02:45 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
About 6 months ago, The rotor burned through and the car just stopped. New rotor and car ran like a champ. My cap and rotor were fairly new as well. Mechanic said it does not happen often but it does happen. Hope this helps
Old Aug 31, 2004 | 03:20 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You should be able to bypass the crane unit if it has the bypass connections like the new ones. Also make sure the dist is actually turning, had a dist gear get eaten through so the rotor was not turning.
Old Sep 1, 2004 | 10:54 PM
Night Hawk's Avatar
I don't think it has any bypass connections.....what wires tap into what?
84z96L31vortec
Aug 20, 2017 12:16 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
g.l.mos
Aug 22, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
