how to remove injectors?
Old Sep 1, 2004 | 11:35 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
hey guys i'm trying to pull off the injectors from the fuel rail and they won't budge.
what am i doing wrong?
Old Sep 1, 2004 | 11:39 AM
Steve89GTA's Avatar
Turn the metal clips
Old Sep 1, 2004 | 11:41 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
turn them?
how far we talking?
Old Sep 1, 2004 | 11:45 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
nvm got it out
Old Sep 1, 2004 | 11:48 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I beleive there is a very descriptive help file on doing this in the tech article section of this site. It tells you exactly how much to move the clips etc. However, having done this myself, I can tell you that even when you move the clips properly, the injectors still don't like to move... i had to put the injectors, one by one, into a vice and pop the fuel rail off of the injector rather than visa versa. I had new injectors though, so it didn't matter if i damaged the old ones... this may not be an option if you're just sending them out for a cleaning.
*edit: whoops, missed your last post, oh well, maybe someone else can use this info.
Old Sep 1, 2004 | 12:38 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
just push the clip all the way over, then put the injectors. they don't like coming out but give me a yank and they will be fine
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
Thornburg
Aug 27, 2015 08:33 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
