Coolant Fan Switch Part Number for 1989 TPI
Old Sep 4, 2004 | 07:02 AM
Dr G's Avatar
Guys:-
I'm looking for some help finding part numbers for a coolant fan switch for a 1989 350 L98 TPI. It's the one located on the passenger side cylinder head between #6 and #8. It's the one used on cars with dual fans, to control the secondary cooling fan.
The problem is I'm in the UK and really need a GM / AC Delco part number or a similar aftermarket one. Basically so I can source it quickly over here.
Any help would be much appreciated!
Dr G's Avatar
I have been searching but haven't found what I'm looking for....
This link tells of GP Sorenson part numbers for various switches with different temp thresholds:-
https://www.thirdgen.org/techbb2/sho...AN+SWITCH+part
I believe the part from NAPA is "Echlin Ignition Coolant Fan Switch
Item#: ECHFS112 Price: $ 15.49" on this link:-http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15591679&prmenbr=5806
Old Sep 5, 2004 | 12:54 AM
357tpirocz's Avatar
If you are looking for a lower temp fan switch another option is an adjustable switch. Permacool, Painless, Flex a Lite, and Summit all offer either lower temp or adjustable fan switches and installation is a breeze.
Old Sep 5, 2004 | 03:13 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Cooling fan switch located passenger side of engine below exhaust header between cylinders 4 & 6; Wells part #SW502.
Old Sep 5, 2004 | 06:10 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
AC Delco #154373 Which also cross references to #10045782
Here is a link to a Picture of it http://www.rockauto.com/ref/ACDelco/15-4373.jpg
Now if you need more info on this Go to https://www.rockauto.com/applet3.html then go down and click CHEVROLET then Click1989 then click on CAMARO then Click on 5.0L 305 V8 MFI Then Click On Electrical-Switch & Relay Then Click on Raditor Fan Temp Switch. I find Rock Auto as a very Very hand part# cross refrence Very Very Often. Hope I helped.
Just my .02
Old Sep 5, 2004 | 04:56 PM
Dr G's Avatar
Many thanks for all the help guys!
Old Sep 6, 2004 | 01:38 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Or different temperatures:
02-4026 Hypertech Cool Fan Switch [cuts on at 176, off at 166 degrees F] $39.99
02-4028 Hypertech Cool Fan Switch [cuts on at 200, off at 185 degrees F] $39.99
Jet Summit P# JET-60600 on at 200* off at 185* $38.69
Robert
Old Sep 6, 2004 | 01:42 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Robert
Or save some money and buy a Coolant Fan Switch for a 1987 Buick Grand National it comes on at 200 of at 180 IIRC
Old Sep 6, 2004 | 05:44 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
3053190 SWITCH
At least thats what Grumpy said the P/N was...
Mine comes on at 210 off at 200, or at least thats what my CTS is showing on mine scans.
Old Sep 29, 2004 | 09:54 AM
Dr G's Avatar
Thanks again for all the help guys!
I justed wanted to let you all know of other interchangeable part numbers for this piece:-
AC Delco 15-4229
B/W TFS1
STD TS-147
Niehoff DR137S
Echlin FS110
Old Jul 29, 2006 | 08:05 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
AC Delco 15-4229
B/W TFS1
STD TS-147
Niehoff DR137S
Echlin FS110
That ACdelco part you have listed, what are the specs on it??? When does it turn on, and when does it turn off?? I desperately need a new fan switch and id really like to go with delco parts.
Also, does anyone have the G/N fan switch ac delco part # and will that fit into a 1992 z28 w/ the Lb9????
Old Mar 24, 2009 | 09:33 PM
85_SS's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
Re: Coolant Fan Switch Part Number for 1989 TPI
AC Delco 15-4229
B/W TFS1
STD TS-147
Niehoff DR137S
Echlin FS110
Hate to bring a post back from the dead here, but do these part numbers cross reference with the 3053190 Grand National switch, or something else?
Old Mar 25, 2009 | 01:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Roostmeyer posted the part number for the Grand National 200* switch and yes its a direct bolt in for our f-bodies.
Old Mar 25, 2009 | 07:07 AM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
Thanks, I was wondering if those were the cross reference numbers for it though as the parts guys around here aren't the greatest.
Is the 203' GN switch the lowest on-setting factory switch? I'd rather not get into aftermarket replacements that are hard to find around here.
Old Apr 7, 2009 | 10:32 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
OLD I KNOW.
Do you think the hypertech 4026 (176 on, 166 off) is too cold for a stock lb9?
Otherwise i might go to the part store tomarrow and get the Grand national switch (210 on, 200 off).
Any opinions welcome!
Old Apr 9, 2009 | 05:03 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I hope so because I just ordered one from TPI Parts. I think it probably would because when I sent my order forms to the person who just burnt a custom PROM chip for me I mentioned I intended to use this switch and asked that the primary fan on/off settings be set to work with this switch.
Old Apr 10, 2009 | 02:28 AM
Kevin91Z's Avatar
Its too cold with a stock 195* thermostat. The fan would run all the time. You'd need a 160* or at most a 180* thermostat.
Old Apr 11, 2009 | 04:19 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
I have a Mr. Gasket high flow 160*F thermostat. Which was one of the questions the PROM programmer wanted to know.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
armybyrd
Aug 10, 2015 09:23 PM
