fuel rail question
Old Sep 7, 2004 | 11:24 PM
thirdbirds's Avatar
Car: 87gta 88notch 89 5spdgta 92 vert
Engine: 5.7
fuel rail question
hey, can anyone answer, if a 86 tpi fuel rail will work with 90 n up speed density intake ? want to change over from tbi to tpi thanks!
Old Sep 7, 2004 | 11:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take the fitting for the Cold Start Injector off the left rail and plug it and there should be no problem. I am using one on my 89 Iroc. I took the tubing for the Cold Start Injector out of the fitting and had a friend weld up the hole in the fitting and turn it down in a lathe. I put a new o-ring on it and screwed it back into the rail, this was two years ago and it hasn't leaked yet.
Old Sep 7, 2004 | 11:58 PM
thirdbirds's Avatar
Engine: 5.7
kool ,thanks trickster was hoping you would answer ! man i could ask a million questions ! lol. your post are very helpful !:hail:
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
