porting
Old Sep 8, 2004 | 12:32 AM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
porting
i have the chance to buy large runners and bigger throtle body real cheap for my 1992 350 tpi. So should i port ot my plenum to match the runners and the t.b. How much will the runners and t.b help. The car also has headers, cold air intake,jet chip. also what size injectors should i put in it?
Old Sep 8, 2004 | 11:48 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
definatly port the plenum, If you want bigger gains replace the baseplate with an aftermarket one while you have every thing off. also do an adjustable F.P. regulator while you're in there. Injectors? unless your making silly horsepower the stock ones should be fine. They are easy to change anytime-Mike
Old Sep 8, 2004 | 12:45 PM
bobsroc's Avatar
Car: 1987 IROCZ
I would,if your plan is to get more air to the cylinders, then free up all passages that lead in. If you browse around lots of guys are doing just what you are asking. Although my motor is not a 350, all this is done including heads and cam. My chip is tweaked some and I am using SVO 19lbs injectors and they can keep up with the increased air flow so my guess is your stock injectors will do the same. Good luck.
Old Sep 8, 2004 | 03:32 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
So your the guy who bought Josh's car? Have you changed anything with it yet? Still looks good from the car domain pic's.
Old Sep 8, 2004 | 09:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sure, port the runners and whatnot. i doubt you will really gain anything significant with the TB. What about the baseplate?
Old Sep 9, 2004 | 02:04 PM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
Any good machine shops in North Jersey or NYC area that can port a stock TPI setup?
What's the normal cost of doing this?
Regards,
G
Old Sep 10, 2004 | 12:22 AM
NYIROC, I port plenums, heads and the occasional base plate. I'm right here in north Jersey. IM me if you want to talk-Mike
Old Sep 10, 2004 | 10:18 PM
purplebird's Avatar
Engine: 5.7 tpi
what base would you guys go with?
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
